As the title states -7 at idle. When first installed months ago it read -12 and quickly went to -10. As of late the gauge has read on the norm -10 and after a bit if running down to -9.When the ac was turned on after the running for a bit it went to -8. It seems to me that i have a vacuum leak. I read that it is generally from maf to turbo, is that correct? This was just noticed late tonight and i have yet to go through all the clamps and connections. I did a WOT pull in 5th gear and boost read 14 then 13 and then 15 and i let off, not sure if that helps. Hopefully this is enough info for people reading but im sure i will hear a lot of check all the clamps and connections.
