according to a stock map loaded in the cobb tuning software ATR, it appears that the stock cut level is 18.21psi from 1000-5000rpm, 17.43psi @ 5500 rpm, 16.66psi @ 6000 rpm, and 14.53psi @ 6500rpm. those values are for fuel cut. the table for when the throttle will close in regards to boost is 16.24psi from 1000-4500rpm, 15.46 @ 5000, 14.69 @ 5500, 12.56 @ 6000 and 9.47 @ 6500.
basically that means if it hits those levels the throttle plate will begin to close a bit to reduce the velocity and volume coming into the engine which in turn will reduce the pressure.
