Ok i am having a problem latley with getting boost cut in 4th gear since the weather has gotten colder when i try to run 18psi. I have a clamp installed and last night i confirmed its working correctly so i am not sure what is calling this. Max pressure i was seeing is 19.5 and it was a short spike. This started happening after i had my race pipe and exhaust installed. On my low boost setting the car is fine which is 15psi.
