Hi all,
I think you know my Cosmo is in the UK and I live in the US. Heading to the UK late July and plan isto use and play with her whilst there.
I'd like to get a boost controller on her and been eyeing up the Blitz SBC Spec-R i-Color. Reason is the dual solenoid, Blitz well proven on the FD
and I want to have display for at least water temp, oil temp and oil pressure. So a few questions:-
1) Anyone have any experience with the i-Color?
2) I know I can purchase the temp/pressure sensors to connect to it but it I can't find reliable info on if I can run all 3 of oil temp + oil press + water temp. Anyone know?
3) Thoughts on using on the Cosmo? Turbos are currently configured to run non-sequential.
Just had my friend in Japan pick up an AutoExe grounding kit (yes yes I know make your own, I did for my FD but time is short in the UK). Hoping this will help with intermittent
inhibitor switch starting until I can locate another one or find the time to investigate a repair. Going to do full fluid/filters whilst tinkering with her. Future plans will be cooling and
all that goodness but not now, again time is short. She has AutoExe air filter and I *think* plug leads, adjustable suspension all around and definitely cat backs and waiting
for a reply on other parts of the exhaust. Not sure what the state of the rats nest is but should be simple seeing as she is currently non-sequential.
In addition to the above, what other mods/changes would anyone recommend I plan for this trip to enjoy her to the full and safe guard her too? Anything else to ponder over
the Blitz i-Color bearing in mind I want a controller and I want to be able to monitor other data aspects?
Thanks
Ant
Thanks
Ant
