Bolt pattern and offset??
ZoomZoom
To those that have swapped their wheels, what offset are you using? Has anybody experienced any clearance problems with either suspension or fenders. Also, what is the actual bolt pattern? I keep getting 5 X 114.3 from various wheel sites, but when I measure it, I get 5 X 4.25 which i believe translates to 5 X 107 or so. I would just like to get some info from those that have changed their wheels before I order wheels and have them send me the wrong ones, it's happened before and it sucks!
Thanks
Griff
Well I'd suggest you contact me as I'm the wheel and tire expert on most forums.
I've test fit virtually every wheel that exists with minimal results. there are only a few that will work without rubbing problems. The reason for this is the need for a very high offset.
If you find a wheel you like please e-mail me so I can confirm it and possibly give you a better price with better balancing. We have the best machine made by Hunter GSP 9712.
Boltpattern is 5/114.3mm or 4.5", centerbore = 67.1.
Rishie
autornd@hotmail.com
