Body roll
83 RX-7 Gsl, 2000 Mazda Protege LX, 2011 Mazda3 Sport i
My p5 seems to just tip through every corner. Is there anything I should do to fix this? I only have the stock parts except I got a rear upper sway bar!
Progress rear swaybar! What you have is a strut tower brace. Not nearly as effective.
Sent from my SM-G900T using Tapatalk
Lower 1.6 inches, progress rear sway bar it'll handle a lot nicer but msp front sway bar will make it handle twice as nice with everything. Tires too definitely helps with the right set.
He never asked for a simple solution to help body rolling, just putting my 2 cents out there for a fellow member.
And second I don't know if that progress bar will work, looks different then the one I installed on my car.
Alright I found my own way there thanks Jackie! But if I was to do the front as well that part number would be?
Front is very difficult to install. I was only able to do mine with the motor pulled. And there is no progress front bar, only option for front is msp, and the only thing it really does is add more understeer.
