BMW Wheels on CX-9
Z-Thrizzle
Mazda CX-9, BMW MZ3 Roadster
I have 3 sets of wheels for my M Roadster.(Street, Track, Snow) Since I'm not using the car in the winter anymore I was wondering if the rims might fit the CX-9.
The specs on the BMW wheels are 18x8 ET:47, 18x9 ET:26. The offset may not be an issue with spacers.
I don't know much about wheels but are they generally interchangeable between manufactures?
No, different manufacturers frequently use different bolt patterns. I believe the CX-9 uses a 5 lug on 114mm circle bolt pattern. It appears most BMW's use a 5 lug 120mm circle bolt pattern. The offset is usually quite a bit different between front and rear drive applications also.
Well it was worth a shot. Thanks for the info.
Similar Threads and Articles
