Modification list added to first post:
2003 Mazda Protg ES-T
Modifications:
Engine Management:
AEM UEGO Wideband Oxygen Sensor
Mazdaspeed Protg ECU
Split Second Air Fuel Controller-PSC1
Engine:
Mazdaspeed Manifold
Mazdaspeed Protg GT2554R Turbocharger
ATP 6-9psi Wastegate
Custom Front Mount Intercooler Kit
o TurboLife Core
o HKS Super SQV Blow-off Valve V3 w/ new o-ring and c-clip
o Universal Piping, couplers/ reducers, and T-bolt clamps
Mazda Protege Intake Manifold
o Ported/Polished
o VTCS Butterflies removed
Mazdaspeed Oil and Coolant lines
2.5 Custom catback w/ hi flo and Megan Racing muffler
Mazdaspeed J/S-pipe
Injen Intake
NSN Motor Sports Thermal Intake Manifold Spacer
ProSport Oil Adapter Plate
Hayden 10 & 12 fan
AWR 95 durometer Front Engine Mount
AWR driver/passenger engine mount inserts
Weapon-R Coolant Resevoir
Millenia PCV Valve
Canister Purge Check Valve
MAM 3 Port Vacuum Block
Greddy Radiator Cap
SpeedCircuit Krank Vents
Oil Pan w/ ATP fitting & Magnetic Drain Plug
NGK V-Power ZFR6F-11 Spark Plugs
Timing Belt/Water pump replacement
Greddy Turbo Timer
JoeP ProZ Manual Boost Controller
Drive Train/ Suspension:
Neuspeed Short Shifter
Eibach ProKit Lowering Springs
Ractive Front Strut bar
AWR 19.5mm Sway Bar
Appearance:
Apexcone 35w 6000k HIDs
SLS Performance Air Diverter Panel
Red painted Brake Calipers
Taillights Tinted
Autometer Triple A-Pillar Pod with:
o SunPro Boost Gauge
o SunPro Water Temperature Gauge
o SunPro Oil Pressure Gauge
ForceFed Steering Column Pod with:
o AEM UEGO Wideband Gauge
Dave B Gauge Cluster Rings
Carbon Fiber Cluster Overlay
