Bluapunkt sub install
06 LS MS6
07 BM GT (shell has been struck from the roll)
Well Finally the correct cross over arrives
the bxn-sub07 for the sub w-100
its a powered suitcase sub that will fit under the seat direct replacement for stock
dilema
the xover apparently has a LOC built in
I have a choice of feeding it with a DIN plug which is likely a herman way of doing shielded RCA stuff OR with speaker inputs all 4 channels
since this will avoid having to solder up coaxial connections from the Blose amp inputs to the DIN cable with unknown terminal choices, I'm thinkin of using the built in LOC,
SO, THE QUESTION
A
leave the xover box near the blose amp feeding it with the four main channels
B
Should I feed all four LOC inputs with a signal from the speaker wire going to the stock SUB
I would be willing to bet blose has tampered with these freq's, one would assume the stock sub has sub freq going to it, but I swear the doors feel like they get the full range signal
(cricket) come on quit (lurk) be part of the (group) do the blose subs get full sub freqs ??
I know that its a dumb Q, but it is blose
