twiztedjeckel said:
so this is why the 93'-95' twin turbo'd RX-7's come with 1 blow off valve and 1 bypass valve? so your telling me that my friend who's got one should change the factory stuff out and put 2 BOV's in place of it?
oh yeah, and anybody who questiond the HKS SS BOV's and said they leak under boost and idle is leaking brain fluids while breathing. they're a PULL type of valve instead of a PUSH type. no leaking there![]()
geez, some people will get so technical on your ass. i have a 93 rx7 so i know that one BOV is called a bypass valve, this is because this BOV vents boost from the secondary turbo until transition which depending on throttle is usually 4500rpm. thats why its called a bypass valve but it is in fact a BOV. i also stated that some twin turbo cars require 2 BOV's for proper operation and the rx7 does have 2 and they are required for proper operation so i was correct
technically it is called a bypass valve and it works slightly differently from a typical BOV but it is still a BOV, thats why i referred to the rx7 as having 2 BOV's
