As of right now I don't have the 11mm studs yet but I am working on getting them. I still have the 10mm studs. I don't have my block o-ringed because I thought that the rubber coated copper head gasket did not need to have the block o-ringed. I have not had time to take off the head yet but when I do, I will take it to then machine shop to see if it is indeed warped. If not then I guess it is the head gasket and I will go with a stock head gasket instead of another rubber coated copper head gasket because I didn't even have 100 miles on the gasket yet and if it is blown........ Doesn't speak very well for it. As far as overheating, I haven't had an overheating problem. Only when this problem just started (car running funny and starting to see oil and coolant on the pistons) did I see the car get hotter then normal.
I checked my oil and it is not milky. The oil and coolant have not mixed in the oil pan or the radiator. So I don't know. It seems like a small leak but it is leaking on all 4 pistons. I will keep you all updated on what I find.
Dave
