AWR makes one but it's on a custom order basis and takes two weeks.azian6er said:so you are saying, just get a stock msp radiator? i dont believe they make upgraded ones for the msp size yet, do they?
-B
If the oil is milky or smells really sweet then you have a leak. Don't drive to long on contaminated oil as it will seize your bearings. Personally I'd stick with OEM gaskets but if you do Copper I'd get APR head studs.LinuxRacr said:I am running the stock Head Gasket with an O-Ringed block (at the advice of Perfworks last year). I may want a copper gasket one day myself. I'm not convinced that it seals completely. I may have some residue of oil in my coolant, but I am not sure. My car is still fast, so I don't feel any compression loss.
My oil is always the normal color when I change it. My coolant stays green. I just may be seeing things. No compression test yet, and I spike to 9 PSI right now. I won't go higher until the new FMIC goes in. I also have no white, or any smoke of any kind comming out of my exhaust. I think the O-ringed block has been saving my engine as well as the J&S. You'd be surprised how much that thing lights up sometimes. With the tuning done this weekend it rarely lights up now. If you don't have one, you don't fully understand the pre-ignition that can happen when you are tuning.ARunto said:If the oil is milky or smells really sweet then you have a leak. Don't drive to long on contaminated oil as it will seize your bearings. Personally I'd stick with OEM gaskets but if you do Copper I'd get APR head studs.
-Alan
