While we're waiting for the Chromed Grille photos:
http://www.msprotege.com/forum/showthread.php?t=123659314
I thought I'd go the other way, and black out the honeycomb pattern.
There are some grille patterns for the RX-8 here: http://www.grille-tech.com/detail.html?prodid=10272&view=1&imgid=1910
Mine is two sheets of offset diamond-cut aluminum, trimmed and framed to 1/4" smaller than the grille opening. I painted it with bumper-match black.
To mount it, I removed the license plate holder. Drilled 6 holes in the honeycomb, and pushed in Mazda plastic bolt assembly plugs (the large kind from inside the wheel wells). Instead of the easily strippable Mazda plastic bolts, I used aluminum screws with rubber bushings, and painted them all black.
The main drawback, is gonna be a lot of bugs getting stuck !
Before:
After: - not such a clean car
Closeup
Before:
Closeup
