Bikingpro5 supercharged Protege5
Status
Not open for further replies.
Got new shoes for the car today.
so it took much longer then it ever should have to get the tires mounted, the 3 tires that they could not get off the rims in one piece now look a bit different.
yea they had to cut 3 of them to remove the sidewall from the tire so that they could remove them from the rim...
also had the car aligned and corner balanced after the new tires were installed.
the toe was out 2.5deg on drivers side and 2deg on passenger side after i played with the height again.
You should find a different company to mount the tires. (Like RUN THE **** Away From them and accept no substitute)
They are using a machine that grabs the inside of the rim with 6 Spikes. Something that you would use on a steel winter rim, but not an alloy..
Totally Ghetto..
Touchless Install..
Totally Ghetto..
Touchless Install..
would if i could, but no touch less install any where near me.. plus im not too worried since there is not a mark on my rims from them, and they have done much more expensive rims then my Speed6 stockers on those machines..
took mine for a 1000km drive to break in the new tires, now i just need to get the oil change again this week (3rd time this year on my summer only car..)
Status
