Biggu's partout TONS of parts + STANCE COILOVERS!!!!
Status
Not open for further replies.
Smitty,
It looks like the gen 1 stuff will fit on a gen 2
I dont know the exact drop range but its low enough for the normal person, if you want "slammed" then these wont get you there without further customizing like sumthai did on his BC's.
Spring rates are 6k/5k, Front Camber uppermount, Inverted Front shocks, OEM type rear springs ,Special designed rear damper allows damping adjustment without removing the coil overs.
15-Way Damping Adjustable, Upper Pillowball Bearing Adjustable Camber Uppermount, Upper Pillowball Bearing Pillowball Uppermount, Spring Cold Wound Linear Spring, Monotube Inverted Monotube Shocks, Collar Aluminum Collars & Upper Mounts, Bracket Height Adjustable Lower Brackets.
Stance probably went with how they did it for adjust ability reasons, Add dampening or removing it etc.
Let me know if you have any questions. still waiting on that new mount, I got off the phone with stance yesterday and they are telling me I should have it on a week or 2 from yesterday.
Local pickup is preferred
I will let you know ASAP, im still trying to dig up all the changes made to the rears on the gen 2 from what i have found all i need is a simple spaced because the thickness of the bushing is different on the bottom. As soon as I can find out ill let you know if I want these.
how did u like the stance coilovers?
did you have to drop the arms in the rear every time you wanted to adjust the ride height?
how hard was it to adjust the dampening in the rear too?
im stuck between these and the yellow coilovers
thanks
-Kyle
Status
