Best of msprotege.com Pre-vote submissions!
hmmm....
some people loves so much mazda that becomes blind against rice. I just like to keep the car as clean as possible.
igdrasil said:
hmmm....
I don't see rice in Woofers car for a couple reasons.
It's pretty tasteful, no giant wings or stupid graphics or outragous jet looking bodyparts. And, he's got the turbo set up to add the performance aspect as well. If he had to, I bet that thing could really move.
I vote for Victor (Pirana) too.
And here's a pic of my car just because.
mmm, spicy. Maybe its just cuz you can't see your tires, but your rims look way small in that pic. Beautiful capture of the spicy color, though.
Thanks. I try to keep my car as far from rice as possible. Yes it is built for show, but it's also built to back everything up. My wife drives this car every day so I had to get an auto tranny. Yet within a month of putting the turbo in, I dropped the cash on my tranny to get it beefed up to hold the hp (the shop told me I'm probably fine through 300-350whp). No slippage, trust me when I say this car is mad fun from stop light to stop light. The only problem I seem to have is it spools way to quick and the shifting, I am at 10psi by the time 3500 rpm rolls around. I have my tranny shop working on reprogramming the shift points. I daily drive it at 10psi and have done so for the last year and a half so I think the tranny is holding fine, engine is forged so I'm not worried about that. I did a dyno run not too long ago, but didn't get the car over 6psi due to a bad vacuum line, still managed 171whp at 6psi though. The car has seen 16psi on occassion when I get a little lead foot
Props to you for what youve done performance wise, I see you have J&S and 440cc injectors... I had some issues running 440s with stock ecu. I still dont like the rims and that rear thing. I guess I just like too much the stock bodykit and the sleeper thing.
bigwoofer said:
Thanks. I try to keep my car as far from rice as possible. Yes it is built for show, but it's also built to back everything up. ....
Just found this thread. There are some BIG contenders in here. Glad to even be considered amoung the elite.
As many of you know, i havent had the best of luck with this car from the start, and pretty much anything that could go wrong with it, has. Basically, like most people on this site, the car was built to be a streetable, daily-driver capable car that didnt sacrifice reliability or driveability for stupid power or exssive bling bling. Most everything on the car has a purpose, but the entire goal was to make the car flow togehter and tie together to creat something special, unique, and impressive.
I only wanted to improve on the stock attributes. The cars mantra was simple: Good braking? We can make it better. Great handling? Lets upgrade everything. Quick? Lets forge the crap out of it and boost it more! Looks sporty? Lets make it have a wider stance and a more agressive front end.
This is only the beginning. Many of you know where this cars new goal of 170mph is going to take it. The end result will be an extenuation of its current state. Clean, tasteful, PURPOSEFUL modifications that blend the entire car into something extrodinary.
Thanks for your consideration in your vote!
Mods:
Engine Build:
- Mental Addiction Shortblock 8.5:1 CR
- CP Pistons
- CP Gold Ring Package
- Olvier Rods
- TOGA Bearings
- ARP Main Studs
- ARP Head Studs
- Double Nitrated Crank
Engine Modifications:
- Perrin FMIC
- Injen Cold Air Intake
- Microtech LT8S w/2Bar MAP
- WRX 440cc Injectors
- HKS SSQV BOV
- TurboXS BPV
- GHL 3" Downpipe
- QTP 3" Electric Cutout
- 626 Intake Manifold (P&P)
- JIC Bullet Catback w/removed Resonator
- Greddy TT Full Auto
- Greddy Profec B Spec 2
- Spec Stage 3 Hybrid Clutch
- AWR Front Engine Mount
- AWR Rear Engine Mount
- AWR Transmission Mount
- NGK 1 Step Colder Plugs
- B&M Short Shifter
- Corksport Stainless Steel Clutch Line
- Kartboy Shift Link Bushings
- Milinea PCV Valve
- Shockproof Lightweight Transmission Oil
Engine Bling:
- All Brackets, Engine Accessories Powdercoated Gloss Black
- Polished Valve Cover w/ Gloss Black Powdercoat
- ApexR1 Radiator Diversion Plate
- DG Motorsports CF Engine Cover
- DG Motorsports CF Oil Cap
- JDM Mazdaspeed Oil Cap
- Hose Techniques Silver Hose Kit
- Greddy Catch Can
- Greddy Radiator Cap
- Transonic Custom Silver Grounding Kit
Interior:
- '03 Sparco MSP Knob
- Sparco "Grip" Pedals
- DaveB Polished Dash Cluster Rings
- Removed Dash Cluster Condoms
- 42 Draft Designs DIN Gauge Panel
- DG Motorsports CF A-Pillars
- DG Motorsports CF Glove Box
- DG Motorsports CF Arm Rest
- DG Motorsports CF HVAC Surround
- DG Motorsports CF Shift Plate
- DG Motorsports CF Dash Cluster
- DEFI Boost D-Gauge
- DEFI EGT D-Gauge
- DEFI Oil Pressure D-Gauge
- Delivery_Guy Shift Boot
- Steeringwheel 52mm Gauge Pod
- AEM UGO WB 02
Car Audio / Electronics:
- DEI VIPER 791XV 2 Way Alarm
- Alpine CDA-9835
- Alpin MRD-M300 Amp (Retro into stock location)
- 8" JL W0-4 (Retro into stock location)
- Escort Solo S2
- HKS CAMP System
Suspension:
- K-Sport 36 Way Adjustable Coilovers (Front and Rear Camber Plates, 1 of 2 in U.S.)
- AWR Adjustable Front Endlinks
- AWR Adjustable Rear Endlinks
- AWR 21.5mm Rear Sway Bar
- Revised "E" Series Bushings
- GT SPEC Front Strut Brace
- GT SPEC Rear Reiforcement Bar
- GT SPEC Rear Lateral Bar
Brakes:
- 13.1" Wilwood 6-Piston BBK (Yellow w/Black Lettering)
- Stainless Goodrich Lines
- EBC Green Stuff Pads
Wheels / Tires:
-18 X 7.5 + 48mm 5Sigen GN+ Pro Racers
-Toyo Proxie 4's
Exterior:
- Blue Bat Taillight Overlays
- XTronic H4 6000k H.I.D.
- AutoEXE Grille
- Gemini Composities Reverse Cowl Hood w/ "Bigwoofer Style" Paint (hi)
- Entire front end reapinted and blended (no more mismatched front lip!)
- 15% 3M Tint
Just to refresh your mind.
I guess the archy will take a stab at it. Gotta represent the laser blue mica........
Mods for the Mazdaspeed:
Greddy SP2 Catback Exhaust
Flowtech Race Readies Cut Out
Injen Short Ram Intake
K&N Air Filter
Hiboost FMIC
Greddy type-S BOV
MAF relocated
Kartboy Short Shifter with Bushings
Greddy Counter Weight Shift Knob
Mather Automotive CG-Lock for seatbelt
Carbotech brake pads
Rotora Cross Drilled and Slotted Brake Rotors
Pro Car Parts Black Housing/Euro Clear Headlights
PIAA headlights hyper blue headlights
DaveB Gauge Rings
Autometer 2 pillar guage pod
Defi Boost and EGT gauges
Apexi Turbo Timer
Perrin Manual Boost Controller
AWR Front Motor Mount
Tein S-Tech Springs
18" 5zigen MK-5 rims 7.5 wide 43 offset
18" Bridgestone Potenza S-03 Pole Position 225/35/18
Xcelerated Concepts Dual Vent CF Hood
JSP Carbon Fiber Trunk Lid
DG Carbon Fiber Grill
DG Motorsports Carbon Fiber Mirror Covers
5% tint in rear 20% up front
MP3 front Grill
Escort Passport 8500 X50 Radar Detector
Pioneer DEH-P8MP MP3 player
about me: well Im an architecture student at the University of Houston. I used to also own a MP3 but had to let her go. ummmmmm........i dunno what else to say.
The Speeds look good, but I gotta stay with the 5s. I just luuuuuve wagons. Where's Smurf? I think his looks good.
here it is
mods are
aem cai
obx header
gtspec everything
custome grill
custome flames and mural
p/p head and mani,and t/b
b&m s/s
soon to be built block
Can't say I've seen that hood before tho'. That might be alittle much. Any engine pix?
Great thread (thumb). There are some really nice cars on this thread. igdrasil, if that is your red wagon you posted, I am really loving the stock look and performance upgrades (turbo, from what I can see).
Keep the pictures coming guys :)
*sigh* Here's My Entry
Everyone before me has sweet, sick, filthy, (insert overused yet still inexplicably cool and "rad" adjective here) rides. I'm throwing mine up there, because it will all change within the next two months, and I'd like to share what I call "my pride and joy"...A car that loves to be driven, yet still goes to shows. Comments are welcome (except for vinyl haters, because yeah....it's my car.)
Oh, and yes, I did post this into the wrong thread earlier, I wasn't paying attention.
*Status Racing Suzuka seats (in yellow kevlar)
*"Trans-Proto" graphics (yes, that's what a Mazdaspeed Transformer toy would look like)
*Old-School NES installed under passenger seat (with controller ports by e-brake and cigarette lighter power button)
*Perrin 3" exhaust
*Perrin FMIC kit
*Injen CAI
*Kenwood double-DIN head unit and screen
*8" Memphis Car Audio subwoofer
*GT Spec Front Strut Bar
*GT Spec Lower Tie Bar
*GT Spec 4-point Ladder Brace
*GT Spec Rear Trailing Arms
*GT Spec Rear Reinforcement Plate
*GT Spec Rear V-Brace
*Painted Mazdaspeed Engine Cover
*Catz HID High-Low conversion
*Trans-Proto graphics (sponsored by RainState)
*Cool hydraulic hood prop thingys
*LiteGlow Orange LED Underglow
*Tinted Tail Lights and Fog Lights
*Vision-X Interior LED accent bars
*GReddy Full Auto Timer
More pics.....
