on point said:my sub sounds good and people swear its a 12inch... and i have to literally show people its an 8inch sub. I just played with the settings one day at work and got it sounding good. I am very pleased with teh sound and dont want to upgrade at all... IF anything new frotn speakers in 5.25 with components....take care and have a nice DAY
just about everyone knows there arent any speakers back there... its not neccessary neways, they got a set in the rear doors to make up for it. oh and the stock amp is worthless for the speakers since its a 2 chan amp while youve got 4 speakers @ 4 ohms each... unless you decide to wire them up 2 speakers to each chan either into a 8 or 2 ohm load. then again you can power just the fronts from the amp and leave the rears going from the deckd_lo said:well... i'm going to rip out that whole inclosure and put it two twleve inch solo baric kickers L7 by next week. I cant stand the factory s***. I also found out that there are no speakers in the rear deck. I'ts just a front. there's nothing there. just a grille so peepz can assume there's a speakers there. i'm going to use the stock amp to run all the highs and mids. its going to sound tight after that. i'll keep you guys posted. peace.
DO WHAT? OMG!!!!DZnutz said:just about everyone knows there arent any speakers back there... its not neccessary neways, they got a set in the rear doors to make up for it. oh and the stock amp is worthless for the speakers since its a 2 chan amp while youve got 4 speakers @ 4 ohms each... unless you decide to wire them up 2 speakers to each chan either into a 8 or 2 ohm load. then again you can power just the fronts from the amp and leave the rears going from the deck
This all depends on what type of amp you want to run, whether or not you go with a dual voice coil sub, and how you're going to wire the voice coils. I won't get into all of it now. It's late and I'm headed to bed. Feel free to PM me if you need more technical info. I'm an audio gearhead from way back and I'll be glad to help.Albert said:Ok, dumb question time - which JL W3v2 do you get to use with the stock sub: D2, D4, or D6 (Dual 2 ohm, dual 4 ohm, and dual 6 ohm, respectively)?
das right... there are 5"x7"s in the front doors and 6"s in the rear doorsMrDiggler said:DO WHAT? OMG!!!!
I haven't had my MSP that long, and haven't torn into the stereo yet. You have to be kidding me! If that's true, then what size speakers are there in the rear doors?
The 6x9's could lend a lot of support to the lower mid-bass and upper sub-bass, if I use the right ones. If there are speakers in the rear doors, that complicates things. I would need 6 channels of amplification for the mids/highs (for the ability to adjust the rear door speakers and rear deck speakers separately) and then my sub amp... Wait...the old Kenwood amp might be good for something after all. I already have a 4-channel and sub amp in the other car, and a spare set of killer Pioneer 6x9's...sorry, thinking out loud. Man, I'm gonna need 2 gauge power and ground wires and another 1 farad cap. Ouch.
Thanks. This works out perfectly. My Escort GT (previous daily driver) has new 6's in the front doors and 5x7's in the rear. I can swap the Krapwoods for the ones in the EGT, throw in my spare 6x9's and I'll be good to go! YEE HA! Lucky me.DZnutz said:das right... there are 5"x7"s in the front doors and 6"s in the rear doors
