bent trailing link
pdhaudio said:
thanks. now, how hard is it to put them in? DIY thing? I mean sheesh, it looks like just two bolts.
Super easy to install. Trust me you can do this.
DIY. No doubt. Only four bolts total and the brake line bracketts.
If you need detailed instuctions please p-m me.:cool:
Patrick
yep. $85.00 for the pair and new urathane bushings.
Also look...
0000-01-3501 RADIATOR ALUMINUM HIGH PERFORMANCE RADIATOR $440.00
0000-01-3502 RADIATOR ALUMINUM HIGH PERFORMANCE RADIATOR - ALLOWS ROOM FOR OIL COOLER $600.00
0000-04-3301 MOUNT URETHANE MOTOR MOUNT SET - FRONT AND REAR $126.70
PRO-FMOUNT MOUNT URETHANE FRONT MOUNT ONLY $63.25
0000-04-3201 STRUT FRONT STRUT KIT - STRUT, SPRING SLEEVE AND ADJUSTER NUT - ROAD RACE $330.38
0000-04-3211 STRUT REAR STRUT KIT - STRUT, SPRING SLEEVE AND ADJUSTER NUT - ROAD RACE $330.38
0000-04-3241 SHOCK FRONT BILSTEIN SHOCK INSERT - SHORTENED - STREET VALVING $169.00
0000-04-3242 SHOCK REAR BILSTEIN SHOCK INSERT - STREET VALVING $99.00
0000-04-3251 STRUT FRONT STRUT ASSEMBLY - BILSTEIN INSERT - RIGHT FRONT
0000-04-3252 STRUT FRONT STRUT ASSEMBLY - BILSTEIN INSERT - LEFT FRONT
0000-04-3253 STRUT REAR STRUT ASSEMBLY - BILSTEIN INSERT - RIGHT REAR
0000-04-3254 STRUT REAR STRUT ASSEMBLY - BILSTEIN INSERT - LEFT REAR
0000-04-9997 SHOCK REVALVE $54.37
0000-04-3302 SWAY BAR 19 M.M. REAR SWAY BAR - 2 POSITION ADJUSTMENT $145.00
0000-04-3320 SWAY BAR 19 M.M. REAR SWAY BAR - FULLY ADJUSTABLE $189.50
0000-04-3303 SWAY BAR 21.5 M.M. REAR SWAY BAR - FULLY ADJUSTABLE $212.50
04-3303-BK SWAY BAR CHASSIS MOUNT FOR AWR SWAY BAR - INC. WITH SWAY BAR KIT $18.75
0000-04-3305 SWAY BAR ADJUSTABLE LINK KIT - FRONT OR REAR SWAY BAR $62.78
19mbushing BUSHING 19 M.M. URETHANE BUSHING / will fit factory horseshoe clamps $54.28
21.5mbushing BUSHING 21.5 M.M. URETHANE BUSHING / will fit factory horseshoe clamps $7.60
0000-04-3306 STRUT BRACE POLISHED FRONT STRUT BRACE - POLISHED ALUMINUM - $176.25
0000-04-3307 STRUT BRACE CARBON FIBER STRUT BRACE $295.00
0000-04-3308 STRUT BRACE REAR STRUT BRACE - P5 ONLY - POLISHED ALUMINUM $125.00
PRO-RBRACE STRUT BRACE REAR STRUT BRACE - P5 ONLY - CARBON FIBER $145.00
0000-06-3401 HEADER 304 STAINLESS 4-2-1 HEADER - ROAD RACE ONLY $499.00
PRO-PCAT EXHAUST CAT BACK SYSTEM - P5 0NLY, COMPLETE
PRO-SCAT EXHAUST CAT BACK SYSTEM - SEDAN 0NLY, COMPLETE / 1.8 & 2.0
0000-03-3301 BRAKES CALIPER BRACKET KIT - FITS FOUR LUG CARS $290.00
0000-03-3307 BRAKES CALIPER BRACKET KIT - FITS FIVE LUG CARS $230.00
0000-03-3306 BRAKES CALIPER BRACKET - FRONT - FOR WILWOOD CALIPERS $137.50
0000-03-3302 BRAKES CALIPER BRACKET - REAR - FOR WILWOOD CALIPERS - 4 LUG HUBS $168.59
0000-03-3303 BRAKES CALIPER BRACKET - REAR - FOR WILWOOD CALIPERS - 5 LUG HUBS $101.50
0000-03-3304 BRAKES FRONT BRAKE ROTOR HATS - TO ACCEPT 12" ROTORS $110.70
0000-03-3305 BRAKES REAR ROTOR HATS - TO ACCEPT AFTERMARKET ROTORS. $110.70
PRO - BRAKES BRAIDED BRAKE LINE KIT - GOODRIDGE / STREET APPLICATION $59.95
PRO- BRAKES BRAIDED BRAKE LINE KIT - GOODRIDGE / ROAD RACE - AFTERMARKET CALIPERS TBA
PRO-1000 FRONT SUSPENSION FRONT LOWER CONTROL ARM - ROAD RACE APPLICATION $380.73
PRO 1001 SUBFRAME FRONT SUBFRAME REINFORCEMENT - FABRICATED STEEL - ATTACHES TO RADIATOR SUPPORT AND SUBFRAME $175.00
PRO 2000 REAR SUSPENSION REAR TRAILING LINK KIT [URETHANE BUSHINGS] - HAS MOUNT FOR EMERG CABLE $85.00
PRO 2001 REAR SUSPENSION UPPER REAR STRUT TOPS - USED WITH AFTERMARKET STRUTS - $85.00
PRO-FDASH DASH COVER FIBERGLASS DASH COVER - ROAD RACE APPLICATION - WILL NOT FIT OVER STOCK DASH $196.00
PRO-CDASH DASH COVER CARBON FIBER DASH COVER - ROAD RACE APPLICATION - WILL NOT FIT OVER STOCK DASH $227.50
PRO-SPIT SPOILER CARBON FIBER FRONT SPOILER - FITS MP3 & P5 FRONT END - ROAD RACE APPLICATION $350.00
PRO- SPOILER REAR CARBON FIBER SPOILER - FITS P5 ONLY $295.00
PRO- SPOILER REAR SECONDARY DECK SPOILER - FITS P5 ONLY TBD
PRO-INLET RADIATOR INLET DUCT CARBON FIBER RADIATOR INLET DUCT - ROAD RACE ONLY / DOES NOT FIT STREET CAR $275.00
COMING SOON
"REAR DISC BRAKE KIT FOR DRUM CARS USING STOCK CALIPERS"
CARBON FIBER PARTS LIST UPDATE SOON
FYI ,I have had AWR rear trailing arm for over 2 years now ,I can say they are great . When I bent my stock ones I had Tony make me a set using stock style bushings . As I live in Canada ,I wanted something that would take our winters . This is one mod that is well worth the money ,Some of you may have noticed the the tail of car likes to dance at high speed ,with the AWR arm the car is soild no dancing . The car will also corner better as the arms dont flex like the stock arms.
Wow, back from the dead. lol
Sorry dude,the $85.00 price was back in 2003.
My, how the prices have changed throughout the years. Still not a bad price, though.
the Gt spec make a lot of noise once the grease has worn down, it needs to be relubed at least once a year to keep noise free
compared to teh stock ones that is
Same thing happened to me. Drove fine but had it replaced at the dealer. I think I paid $42 for the peice and then whatever the labor was. In total it wasnt that expensive. If you could upgrade to the better ones then go for it.
Good luck with that..
Pete
