I recently change from main seal and oil pump water pump oil pan gasket and valve cover gasket oil feed lines and all new timing belt.
I am leaking from my new cam seals and the cam gear seams warped? And when I take the cam cap off close to tell cam gear on exhaust side there is a lot of scaring on the cam cap and cam?
Do they make aftermarket cams for these cars if so can anyone help me find some I've been looking for the past week.
I am also replacing the head. Is there anything else I need to do while the head is off? Piston and rings look good and feel good no movement inside the cylinder.
