OK, I'm a failure! I did NOT replace the belt tensioner or belts today. I got all ready to decided to due the "take-off-the-right-front-tire-and-splash-shield" method. I did that and unfortunately, unlike the Mazda3 in the video, the belt tensioner in the CX-5 is in an almost impossible position. I gave it a shot but I couldn't even release the tension to remove the serpentine belt. So I closed it all up and I'll bring it (and all the parts) to my favorite mechanic and let him have all the fun! To be fair, this is "probably" DIY doable if you have a lift since the working position would be much better, but I don't have a lift.
This is a picture of my dirty tensioner. Leaking? Beats me, but it makes no noise.
And after removing the tire and the splash shield, here is the view. Lots of metal in the way of where you need to get too. Tried both from this angle and the top before I gave up. Can't imagine that the standard shop time for the swap is .4 hours of labor!
minnesottaart,
While at your mechanic ask him to look at the crank pulley as well.
May be its normal but it kind of seems to have some cracks in early stages. Primarily the rubber part in between outer and inner of it
Interesting. Your package has part number PET2-15-980, but the tensioner itself says the part number is “PE03-15980 K0255” (PE03-15-980) with serial number “F-569897.10” ⋯
Not a failure lol. You need the right long reach wrenches for leverage or be pretty strong. I purchased a long reach 17mm wrench as shown a couple posts back. For anyone wanting to remove the tensioner just get a kit that contains both the 17mm and 12mm wrenches. And not just long reach but Extra long reach.
Something like this https://www.amazon.com/dp/ (commissions earned)
Any chance we can use a breaker bar/socket in there or is there not enough clearance?
FYI, HF sells the long reach metric wrenches for $24.99 if anyone wants to save money
Metric Long Handle Combination Wrench Set, 11 Pc.
Sizes: 10mm, 11mm, 12mm, 14mm, 15mm, 17mm, 19mm, 21mm, 22mm, 24mm, 26mm
By looking at the illustration from FSM, it seems an offset box wrench is needed. How do you use 17mm extra-long wrench without offset to turn the cast hexagon and loose the belt without interfere by the crankshaft pulley from the bottom side? And how do you use no-offset 12mm extra-long wrench to loose the bolts on tensioner which are recessed inside?The tensioner is right up against the engine bay. Space is really tight. You'll need wrenches with a box end.
The HF long reach metric wrenches............trust me you want to go longer. HF's long reach 17mm wrench is 12 inches whereas my extra long one is 16 inches. You could join two wrenches together but with the tight space I prefer the specialty extra long reach wrenches. That said the HF 12mm long wrench is 9 inches is actually not bad. I don't have the strongest arms therefore I'm looking for a 12mm wench at least 1 foot for more leverage.
Here's the 12mm one I'm thinking of getting: 12mm extra long box end to remove the bolts.
Here's the 17mm I currently have. Perfect for releasing Tensioner tension: https://www.amazon.com/dp/ (commissions earned)
Edit: the reason why Mazda techs and mechanics can get away with using standard sized wrenches- Its because they have the car lifted up. They merely use their body weight and pull/push from below the car. For us DIY's were crouched down inside a wheel well having to use forearm strength. Not fun![]()
Drive Belt Auto Tensioner Installation Note
CAUTION:
To allow the drive belt auto tensioner to function correctly, always bleed the air from the drive belt auto tensioner using the following procedure after assembling the drive belt auto tensioner.
1. Install the drive belt auto tensioner to the engine.
CAUTION:
• To prevent damage to the drive belt auto tensioner, do not apply excessive torque after the tensioner moves full-stroke.
2. Insert the wrench into the cast hexagon on the drive belt auto tensioner, move the drive belt auto tensioner up and down at full-stroke three times to bleed the air.
NOTE:
• By moving the drive belt auto tensioner up and down full-stroke three times, the piston inside the tensioner moves to bleed the air.
Mazda FSM dose say bleeding the air of the belt tensioner is required after the installation. No mention about the torque value of the tensioner bolts, or if new bolts are needed.
Move the drive belt auto tensioner up and down at full-stroke three times to bleed the air.
Here's a larger pic to show the cracks. I guess we'll see what happens.zoom in on the last picture on page 6 and you could see the micro cracks.
its still early stage from what I could see on the pics.
Pause to 7:00 mark of this video tensioner. Image that but closer to engine bay since vid shows a 2.0 liter engine.
Tensioner bolt: My extra long wrench has a 15 degree offset but what really helps is being boxed in the end. The boxed end helps extend grip sideways (90 degrees) to capture the Tensioner.
On Bolts you can get away with 0 offset:
Bottom Bolt- it sticks out more (whereas the tensioner bolt is more recessed) so even a 0 offset with boxed end can grab it. Again look at 7:00 to compare the 2.
Top Bolt: Good news! There's nothing in your way. Leverage would be nice though. Its the other two that are the issue.
Minnesotaart: You start not with a shove but more of a constant push. Don't worry if it doesn't move at first just apply a constant push for like 5 seconds. It feels like pushing into a brick wall I know!!! Then all of a sudden it starts to give up slowly but surely allowing you to go counterclockwise. I agree a lift is better.....if I had the money.
Edit: Was at Harbor freight today and saw the metric Long wrenches in person finally. They keep selling out.....hey they may actually work.
Thanks for the video. At about 15:20, he has a serpentine belt tool and I found it on Harbor Freight. Looks like there's no need for a offset box wrench if that's the case since the tool is slim enough to fit in the crevices. Maybe the only issue that we'll run into is torqueing it down.
Serpentine Belt Tool Kit
Look at a bunch of those online and the common complaint was they broke. Twisted the square socket head right off the body of the tool.Thanks for the video. At about 15:20, he has a serpentine belt tool and I found it on Harbor Freight. Looks like there's no need for a offset box wrench if that's the case since the tool is slim enough to fit in the crevices. Maybe the only issue that we'll run into is torqueing it down.
