Not so much the whole alignment but the camber will change because your car making the body shorter/longer. Its just best to find the ride height you want and then get it aligned afterwards.
^^^ cant do it at those places... need to go to a legit aftermarket car shop and get an alignment.. those other places dont align lowered cars..
no way... prob didnt do a good job id assume... the only reason i even say this is that well its not reccomend at these shops and ive asked shops if they wold do it and they say no.. at all the low places. like midas and shyt..
edit- what places in florida.. where maybe ill go.
IM GUILTY OF THAT ALL DAY!(butthump)Toe can change as well along with camber. You could be a dick and get one of those lifetime alignment deals at a tire shop and piss them off by coming in every other day making changes. lol
find a performance alignment shop or just find a little shop around the city that uses mechanical gauges to do your alignment, all old school. If you go to some bad place like evans tire or tires plus they will put your car on an electronic machine and try to put it into factory specs, which are no longer needed because your are not on factory suspension anymore. And to whoever asked earlier, yes, you do have to get an alignment after every adjustment you make to the susp. so get it how you want b4 the alignment
yeah most will, but I have had shops refuse to do "custom" settings that may or may not be within factory specs. I found a cool little shop that will do anything you want and they are cool about me being right there while they work on my car.
