BC coilover install
anyone know if there is a how to on this or know how hard it is???
Fronts are easier but if you get the camber plates you have to drill out the strut towers with a 3 in bi-metal whole saw.
Rears you will want adjustable rear camber links to solve the negative camber problem you will get from lowering the car. This is the biggest problem. Right rear camber link requires a lot of work due to poor location.
