AWR Short Radiator
I have it, the only issue i have is i had to trim my fan shroud to fit it on, but i removed my a/c a while ago so i dont have to worry about the condenser. it works nicely and looks great but is made to order.
Unless you're getting for dirt cheap, you'll have an easier time and better gains by going to a Front mount setup (cheaper too). That way you don't have to trim fans, worry about the AC condensor or any of that. You can get a FMIC kit off ebay for around $100 and grab a Mishimoto Radiator and shroud from CR3 Motorsports for about $400. That'll include a great radiator, shroud, and 2 12" slim fans. Most AWR radiators I've seen go for $500 alone.
try to get full size radiator, even a no brand full size aluminum radiator are way better choice =,=
keeping engine in proper working temperature is key for longer life XD
problem is you have to get FMIC too. which adds up the total cost
