thecrash91
- 2003.5 Mazdaspeed Protege
worth buying over stock? one of mine is shot in the front, will it help my cornering around turns fast?
If you don't live in salty winter places they are cake to remove & the sway bar made your car handle better, the endlinks did not. I see in the pics that either awr improved the rubber bushings or you did the firewall grommet klunk fix from the how-to section. That's the reason they are quiet. Might wanna square that one in the 2nd pic up a bit so the rubber will last longer. Many had issues in the past, maybe awr improved the design?Love mine...no noise at all. I installed the Progress rear sway bar as well. Worth it in my opinion. You will most likely destroy the stockers when removing them. The car handles so much better now!
