please do yourself a favor if your 04-09 mazda 3 is in need of door mirrors go oem used or new the tyc ones are junk, the oem painted covers do not fit the tyc mirror, and upon inspection of the motor and internals of the assembly i saw exposed wires (this being an external part that gets water all over it, should be well shielded) and the glass connects in a completely different way, so if replacement glass was ever needed you'd be out of luck. i saw this immediately returned mine to amazon and went oem used for just slightly more. the oem may have a design flaw with glass rattle but with the cheap feal, look and make up of the aftermarkets i will stick to oem on this part.
