auto trans fluid change
dusterbd13
03 P5
spec says it requires mv fluid. only thing I can find that meets the spec is oriellys brand global atf.
any ideas? or is there something elso I should be looking for?
Just an FYI...
Some guys on the forum said that when they changed their ATF their transmissions went to complete crap.
Apparently if your ATF is brown and smells burnt and maybe has never been changed then you are supposed to drain and refill slowly.
Some guys even saved all their fluid after a rebuild and put it back in.
