muhkaydenz
Auto trans bucking engine light flashing HELP!
So it's an 03 protege auto trans with 128,000 miles doesn't want to drive when warm, it bucks in first and reverse after it gets into second on up it's fine I replaced the intake tube spark plugs, cables, and air filter. I think it's the trans or a sensor having to do with the trans cause if I put it in neutral it doesn't do it. It has fluid so I'm not sure what the next step would be. Once while it was bucking it threw a code that was a random misfire p0300 or something like that thanks!
