Ignition?
So, from as best as I can tell, you connected in only four places to your car: Headlights Out, Parking Lights Out, Constant 12V Source, and Ignition (obviously a ground wire as well, but that doesn't require tapping into any other wires). Is that correct? If so, what purpose does tapping into the Ignition wire serve? Did you use any diodes in your installation?
Also, it appears as though my Headlights and Parking lights output are a single wire from the headlight switch in my steering column (rather than two separate outputs). In this instance, do you think I should simply connect the Green 545T wire to that source, and not tap the blue wire into my system? Thanks for any and all suggestions, and thanks for giving such detailed instructions and pictures!
