BigB said:Gran Turismo East, none better.
i ask because i bought a lifetime alignment at firestone for $99. I've used it 4 or 5 times now. They set the front camber and toe to what I ask. Does Grantourismo use any other special equipment?BigB said:Umm... they charge you the same price if you hit a pot-hole and **** it up. It's not like they come with warranties.
It usually is $80 for 4 wheel and $40 for 2 wheel. But prices may vary.
Rogue said:i ask because i bought a lifetime alignment at firestone for $99. I've used it 4 or 5 times now. They set the front camber and toe to what I ask. Does Grantourismo use any other special equipment?
Velocifero said:sorry to jack the thread but somebody has sand in their mangina
I'm so sure we're all at that level where that "last little bit of camber" is going to be the difference between 1st and 2nd place.BigB said:Such as what? It's a Hunter Laser Alignment rack and Jeff has been doing alignments for 30 years. He does most of the local race cars as well as out of towners here for races.
But what do I know, I"m sure Firestone is top notch and knows how to squeeze that last little bit of camber out for you, or set up the toe to account for your weight? Do you always have the same tech at Firestone who knows your car?
NM I even said anything.![]()
will you be able to do one in the next couple weeks? I'd like to get the miata at least aligned (won't have a chance to get it corner weighted) before the 1st event.Shadow102 said:well if you want a place that is cheap but has no warrenty let me know
aMaff said:will you be able to do one in the next couple weeks? I'd like to get the miata at least aligned (won't have a chance to get it corner weighted) before the 1st event.
aMaff said:I highly doubt I'll be able to corner weight it in time, but I know where I need to set the heights (more or less). Won't be optimal, but it will be even.
