My 2008 CX9 recently started showing the AT light on after starting and shifting into reverse. The car was then stuck in third gear. After shutting it off and strting it again everthing worked fine.Took it in to my dealer and they could not come up with anything as by now the check engine light was off. They suggested it might be the battery. Stating if it wasn't providing sufficient electrical out put this could affect the computer.I purchased a new battery and the problem disappeared for about too weeks. Once it started happening again I happened to be near an auto parts store that check codes for free. They came up with the following three codes;
1)V0100 (???)
2)V0073 (Communication with engine module failure)
3)V0101 (Communication with transmission module failure)
Anyone with any ideas on what would cause this and if it is difficult to fix?
1)V0100 (???)
