if I remember correctly every 10 db is twice as loud so 6 would be quite noticeable.
In the video are they actually driving or just revving the engine?
From what I've read the mat type stuff they used is mostly for improving the quality of the sound from high powered sound systems in the car as it stops the cars body from resonating and distorting the music as it bounces back off. Most everything I've read said that stuff doesn't do much for killing road noise as it takes 3 or 4 layers of it to build up enough mass to absorb sound passing through. Granted stopping it from resonating will quiet some noise but the thicker MLV (mass loaded vinyl) is what I've read will kill road noise more. That's just what I've read on a variety of sites. The MLV tends to be a more solid layer of vinyl sandwiched between other softer layers or a solid layer on top of a softer layer. There are also products with a thin layer of lead between two lighter foam layers
http://cascadeaudio.com/car_noise_control/vb_3.htm . All the foams are closed cell to avoid absorbing moisture.
One site claimed that while you can get away with just partial coverage with the peal and stick dynamat style stuff (because even a small amount can reduce the tendency of the metal to vibrate) the thicker MLV needs to cover 100% of the area you are trying to stop the noise from coming through otherwise even a small uncovered area will let most of the noise through. Haven't seen any tests to prove it though.
I can say that in the past I've used a lot of dynamat extreme with very little end effect on road noise. The thicker foams seem to have a lot greater effect on it. The downsides with those are you generally have to glue them to vertical surfaces and you can't fit them everywhere as they can get in the way of panels fitting back into place or even push the carpeting up on the floor.
The frost king stuff is quite light. A 15 sq ft roll weighs next to nothing, expecially compared to some of the other dedicated products.
I wonder if it is different from what saynotopistons used as it isn't tar based, it is a foam insulation. I've seen online where people have used peal and stick roofing patch that is tar based and I could see that smelling. But I haven't read any comments on smell from the frost king.
There really aren't many good comparison tests out there that I could find on the different products, especially for killing road noise. I guess it could be hard to test as one car magazine pointed out once printing the db levels of the cars they test isn't really conclusive as some sounds are annoying and some aren't as bad so one car at 75 might be more pleasant for a long drive than one that measures 72. The same thing could happen here where one could end up dropping the overall db level but still end up with a lot of the annoying and fatiguing sounds.
The product I found that was the most intriguing to me was from 3M, it is Thinsulate Acoustic Insulation. It does for sound what thinsulate does for heat.
Thinsulate Acoustic The problem is I couldn't find any retail source for it that sold it in less than $1000+ special order amounts.
Trevor
Genuine Factory Mazda CX-5 Accessories
