Running stage 1+FMIC, dont have dp and rp installed yet. I get the boost to peak at 16.5 but it wont hold. by the time i shift the boost is down to 12psi. ive had the stock bpv on and couldnt get more than 15.5psi out of the same map. the turbo xs hybrid bov i could only get 15.5psi out of as well. The HKS deffinitly holds the boost better but im not sure why it trails off.
I still have the txs bov and may put it back on and add a spacer.
any thoughts as to what else it could be??
