M moll88 Member : 08.5 mazdaspeed Jun 13, 2009 #1 i cant hit full boost and i dont know why ? Attachments datalog7.;net.txt datalog7.;net.txt 19.9 KB · Views: 236
D dread Member Jun 15, 2009 #2 Im not sure how your forge wastegate would affect the ots tunes, but that may be your problem. What map are you running. The nano is also not compatible with the ots maps. If those are not your problem you have a boost leak.
S Speed3Rookie Member Jun 15, 2009 #3 He has a MAP clamp so I don't know how he reading boost unless he has a boost gauge.
M moll88 Member : 08.5 mazdaspeed Jun 15, 2009 #4 thanks guys it was the forge wg i shortened the arm some more and wow it feels like a completely diff car
