Anyone's timing belt snapped and bent valves?
*RESULTS ARE IN!*
I have two bent exhaust valves (yeah only two? huh weird) and need valve guide seals replaced and head resurfaced
Valve to valve interference would have exhaust valves hitting intake valves.
Two exhaust valves won't hit each other even if they're in the same cylinder.
I've bent valves but not from the belt snapping but from the timing belt spring rubber getting into the timing belt and throwing off the timing. After I re-timed it you could hear a faint tapping sound. The more I drove it the worse it got.
