SallySpeed3
- GT Mazdaspeed3, Cosmic Blue
Hey guys. I know Cobb has started to limit production on these so if you're thinking about getting one, better do it now. Just installed mine the other day and I am completely happy with the feel of the shifter. Install is not bad at all. If you have ever swapped out your shifter spacers for better ones, you'll have an even easier time with it because you've taken out the center dash before. My only complaint is the clicking sound I was getting from the return spring. It's just the springy wire that holds the shifter in place. It's a real easy fix. All you have to do is get a sharp knife, preferably on the small size and grind down a little groove where the spring hits the plastic. You'll see what I mean if you get it, and problem solved.
I would post pics of my install, but again, it's easy and the pictures Cobb gives you with their instructions are basically good enough.
