It just that if the DH can read AFR from our stock wideband, then why can't the Standback? It would save tuners a few hundred bucks not having to buy another wideband.
Heres why I said that.
4-10-2007 Jordan from CP-E "Unfortunately it can't, and I'm sorry to say that I doubt any tuner in the near future will be able to either. I, like many others, were under the assumption that you could just tap a wire on the WBO2, sense a voltage, and convert the signal to indicate an air/fuel ratio. The problem is that unlike narrowband O2's, wideband O2's use current to indicate the air/fuel ratio. You measure current because the sensor is basically a narrowband O2 with an ion pump attached to it. As oxygen in the mixture increases, the current going to the ion pump decreases, and the opposite is true for a rich mixture.
This is a problem because you can't sense the current within a circuit without disrupting the circuit itself. In other words, the feedback loop attached to the ion pump would be skewed, and the readings would no longer be valid once you start altering the circuit. So there is a real hurdle there.
Secondly, even if you're slick enough to sense the current to the ion pump without disrupting the circuit, you still need to make sense of the output, and how the feedback loop is controlling the pump. One may expect the sensor output with respect to air/fuel ratio to be linear, but that's almost never the case. And the signal is also probably pulse-width modulated, which makes the output even more confusing.
So it is possible, but the task isn't striaghtforward by any means. You're much better of just buying an aftermarket wideband while we try to make more sense of this car. Since our Standback will only accept sensor signals from our wideband (which is unfortauntely unavailable at the moment) we'll be offering an analog hub which will accept signals from any analog sensor. The neat thing is that it'll integrate the datalogs into one file. But you can go crazy and get sensors to log things like suspension travel, acceleration, exhaust gas temperature, the uses are endless, which makes the hub a pretty neat addition"
