My callaway manifold cracked... Before my engine build was done.mx3ownzj00 said:can I ask why? the cast iron callaway one is hella strong.
DC Sports is making one btw.
EDIT: I'm too slow![]()
That's a good question.mx3ownzj00 said:but was that do to improper casting, strain etc?
The GT28RS bolts right up, however on mine we had to replace the wastegate actuator with the one from the stocker because the one on the GT28RS came to close to the engine block in it's position from the factory.Speed Vision said:Jrod, just curious as to whether or not you could bolt the GT28RS directly up to our manifold. Or is there something that has to be done to do this correctly. Thanks in advance..
