ANYONE know if this will work?
spdjnke
08.5 CWP Speed3 GT (sold)
Hey all,
I dug up a set of 16x7.5 Sport edition wheels mounted with snow tires at my parents house left over from my 03 Acura TLS I totally forgot...well any chance you wheel guru's can tell me whether they will fit my MS3 or not without shims.?
16x7.5
50mm
5x114 have hub centrics rings
back space is 6.25
Thanks!
Seriously?? I believe the center bore for the MS3 is smaller then that....or I guess I can just leave the Hub centric rings out and that should take care of it IF it's bigger...guess I'll have to do test fit this weekend....if it does work, that's another set I can sell to the community for cheap.
If the wheels have rings in them then they are likely 73.1 naturally with rings that drop them to 64.1.
Most aftermarket wheels come with a 73.1 hub bore.
You'll be fine if you replace the current hub rings with ones sized for the MS3.
