anyone bled their clutch yet?
molex7
2012 mazda2 sport
was wondering if anyone has ever bled the clutch on their 2 and could perhaps point me in the direction of how to perform the operation.
I have. It's pretty straightforward. Have someone push the clutch in, crack the bleed screw on the slave cylinder, close the bleed screw, let clutch up. Repeat.
Yep. Same as brake bleeding, only difference is you have to physically pull up on the pedal as it doesn't return up on its own.
Also IIRC the bleeder is a bit weird, you have to unscrew it nearly a full 1/2 turn before you get fluid out as it seals a bit differently?
If the clutch line has never been opened you should be able to just gravity bleed it(albeit it takes more time) most likely. If actual air bubbles are in the system you want to forcibly bleed it.
