Another P0171 (with a sprinkle of P0301)
toedrag
2002 PR5
Just documenting my experiences with what started out as a P0301 (Cylinder 1 Misfire), which then morphed into a P0171 (System Too Lean (Bank 1)).
Stock 2002 MP5 with 112k currently. original owner. (thumb)
I had been noticing a gradual decrease in fuel economy over the past couple of years and was never really sure how to begin troubleshooting, so I left it alone. About 6 months ago, I noticed some rough idling, and again left it alone because it wasn't bad enough to annoy me. Then the idle got worse, not to the point of stalling, and I eventually got a P0301. I swapped injectors on cylinders 1 & 2, and after a few days the car popped the P0171 without any other codes. (To date, P0301 has never returned). I ended up deciding the injectors were dirty and sent them to DW for cleaning and servicing. DW also provided a new set of injector seals (lower O-rings). I installed them, and idling issues appeared to have been resolved. Over time, idle issues came back and my fuel economy took a horrible turn for the worse. I have been barely getting 300mi to a tank these last couple of weeks, and I know that in the past I could squeeze out 360-380 mi. P0171 came back a couple days ago, and after lurking on this site some more, I did the ol' starter fluid spray test because I could hear a faint hiss coming from the intake side. Sure enough, when I sprayed anywhere around the injectors or intake manifold, the engine idle changed dramatically. I assumed that the injector seals must have been okay b/c why would DW provide improper seals, so I changed the intake manifold gasket. That seemed to help a little, but when spraying directly on the injector seals, it still created dramatic idle changes on all 4 injectors. So, I ordered 4 new stock injector seals and installed them. Now, spraying the starter fluid has no affect on the idle.
Looking back, I suspect my problem was likely bad/old injector seals from the beginning, and while I can't really be sure if changing the intake manifold gasket or injector cleaning was necessary, they weren't a waste of time or $. I also can't explain why DW's seals seemed to disagree with my IM/block. Physically, they are a different shape and did feel much looser when the fuel rail was torqued down, compared to the stock seals. YMMV. This was also a lesson in "always start with the simple stuff" --> Changing the injector seals should have my first step, not my last.
For now, I've got no more vacuum leaks that I know of, and the idle seems rock solid (except when the AC in on, but that's a problem for another day). We'll see if any error codes come back.
fyi, changing the IM gasket only took about 3 hours, going exceptionally slow. And, it was pretty easy to remove just the top half (leaving the dynamic chamber in place). If nothing else, it's another skill added to my toolkit.
That IM work will come in handy if you ever wanna remove the clattery ass flow blocking VTCS mess from the IM. You only need the top half of the IM off to do it. That's only there for cold start emissions and it only uses them for first minute of car running so the rest of the time they are just noisy dead weight. I live farther south so it doesn't even get cold enough here for it to even be an issue & not thinking it'd be any issue for you in Big D. It might matter if you lived where winter was actually a season vs. just a sampling of it here and there for a month or 3. Injector seals woulda been down the list for a lot on here after plugs, wires, coils, intake accordian rubber piece being cracked, cleaning egr and IAC valve so don't beat yourself up on that, lol. The practice you got will be helpful for future problem solving work.
P0301 finally came back (almost a year to the day later).
Prior to the code popping, she had occasional trouble idling. RPMs would drop a bit, but it never stalled. I cleaned the EGR valve, which didn't really make a difference. So, I just decided to wait for a code...
After getting the P0301, I had a hunch that air & fuel were fine, which left spark. Since I'd replaced the plugs less than a year ago (and each looked fine upon inspection), I swapped the Ignition Coils, cleared the code, and waited. The very next day, she popped another P0301, which suggested that it's not the Ignition Coil, but the wire set on the #1 plug. I bought a new wire set, put the Ignition Coils back where they were originally, cleared the code, and now I'm waiting again....20 miles in, and so far so good. Fingers crossed.
Thought I'd bring this thread back from the dead. I had replaced the IM gasket when I repaired a butterfly valve issue. Turns out I didn't get a good enough seal either on the gasket or one of the injectors. Took everything apart, cleaned it, and put it back together. 10 miles or so and no CEL and no pending codes. Now to figure out what is wrong with the A/C. Thanks OP for posting this.
