Just documenting my experiences with what started out as a P0301 (Cylinder 1 Misfire), which then morphed into a P0171 (System Too Lean (Bank 1)).
Stock 2002 MP5 with 112k currently. original owner. (thumb)
I had been noticing a gradual decrease in fuel economy over the past couple of years and was never really sure how to begin troubleshooting, so I left it alone. About 6 months ago, I noticed some rough idling, and again left it alone because it wasn't bad enough to annoy me. Then the idle got worse, not to the point of stalling, and I eventually got a P0301. I swapped injectors on cylinders 1 & 2, and after a few days the car popped the P0171 without any other codes. (To date, P0301 has never returned). I ended up deciding the injectors were dirty and sent them to DW for cleaning and servicing. DW also provided a new set of injector seals (lower O-rings). I installed them, and idling issues appeared to have been resolved. Over time, idle issues came back and my fuel economy took a horrible turn for the worse. I have been barely getting 300mi to a tank these last couple of weeks, and I know that in the past I could squeeze out 360-380 mi. P0171 came back a couple days ago, and after lurking on this site some more, I did the ol' starter fluid spray test because I could hear a faint hiss coming from the intake side. Sure enough, when I sprayed anywhere around the injectors or intake manifold, the engine idle changed dramatically. I assumed that the injector seals must have been okay b/c why would DW provide improper seals, so I changed the intake manifold gasket. That seemed to help a little, but when spraying directly on the injector seals, it still created dramatic idle changes on all 4 injectors. So, I ordered 4 new stock injector seals and installed them. Now, spraying the starter fluid has no affect on the idle.
Looking back, I suspect my problem was likely bad/old injector seals from the beginning, and while I can't really be sure if changing the intake manifold gasket or injector cleaning was necessary, they weren't a waste of time or $. I also can't explain why DW's seals seemed to disagree with my IM/block. Physically, they are a different shape and did feel much looser when the fuel rail was torqued down, compared to the stock seals. YMMV. This was also a lesson in "always start with the simple stuff" --> Changing the injector seals should have my first step, not my last.
For now, I've got no more vacuum leaks that I know of, and the idle seems rock solid (except when the AC in on, but that's a problem for another day). We'll see if any error codes come back.
fyi, changing the IM gasket only took about 3 hours, going exceptionally slow. And, it was pretty easy to remove just the top half (leaving the dynamic chamber in place). If nothing else, it's another skill added to my toolkit.
