Another Mazda5 HID install... (pics)
jandree22
2007 Mazda5
Well, finally got my Apexcone HID's installed in my 5. Took some trial and error, but thanks to the help from dreamym5, got them burning perfectly. (What hung me up was the little 'tab' on the bulb... it needs to be aligned between the two metal posts inside the projector housing, or else kiss any respectable beam pattern away.)
Anyway, I'm completely happy with them... simply beautiful! The roads were wet tonight, and any time the roads are wet, the light reflects and refracts so it's hard to gauge the brightness you'd see on a typical night road that's dry. What I will say about the brightness, is my eyes adjusted to them so I didn't think they were much brighter, until I turned on my high beams and they were actually kind of dwarfed in intensity by the HID lows! (Note that the HID's stayed low height and the high beams shot at a higher level, so there was still separation of the light, but the HID made the high beams look weak). This is also a good time to note that in about 90 min of driving tonight, I was not flashed with high beams from other drivers, not even once.
Okay, that's the intensity... now my favorite part, the color. I got a set of 4500k Apexcone's. These babies are sweet... NO YELLOW, trust me. Pictures can make them appear yellow, but seeing my reflection in glass windows and behind other cars, even the 4500k's have a subtle purplish hue (and not the cutoff, the 5's projectors don't seem to cast a blue/purple cutoff line, mostly greenish/brown). So as far as how they look from outside the car, you'll not be let down by the 4500k. Now, as far as how the road looks from within the car, pure white. There's absolutely no blueness cast on the road. Like I mentioned, the wet roads made it hard to tell what exactly they'll look like when on dry roads... but a few objects that stood out as exceptional are, concrete barriers and metal guardrails were lit very bright and clear, reflective surfaces such as road markings and speed limit signs jump out at you more, and although trivial, one thing I love is how GREEN the grass looks... beautiful stuff! Bottom line, if you're on the fence, I'd say go with the 4x00k color temp, I highly recommend it, you get very clear road lighting and still be a bit of blueness in appearance to onlookers. I think 6000k would be too blue for me. Ultimately, it's just personal preference, though.
Okay, time for pics. You won't find any road/beam patterns here... as mentioned, the roads were wet and it would make for lousy pics... I'll try to get some of these shots sometime in the not-so-distant future.
OEM Halogen left, 4500k HID right. (I know there's glare here, that's what happens when you place your camera directly in the line of fire :p)
Another side-by-side
Head-on closeup - Halogen
Head-on closeup - 4500k
Angle closeup - Halogen
Angle closeup - 4500k
Top-down closeup - Halogen
Top-down closeup - 4500k
Both HID's installed... pic taken just above cutoff line
Both HID's... pic taken below cutoff line (ie, direct shot of beam)
HID projector cutoff line...remains greenish/brown as with the Halogen's
Engine bay post-install. Note the Apexcone(DDM) slim ballasts by the coolant reservoir and fuse box. The relay harness runs behind the engine.
Mounted the ballasts using heavy-duty velcro tape. Tucked in all the connections and igniters into that fender cavity you see here.
Same deal, driver's side of the car. You can also see the relay harness ground.
UPDATE: 5/24/08 - Beam pattern & Action shots added
Beam pattern, like 10 ft. away from the wall. Note the dreaded 'glare spots' above the cutoff line. I must say that in person they're as weak looking as they are in this pic. Furthermore I stepped out and put my face in one of those three spots, and nothing significant changed... dropped below the cutoff, and sudden blindness :D
Beam pattern, like 30 ft. away from the wall. Now check out the dreaded 'glare spots'... they're virtually gone. So I don't think they're an issue with the 5 as discussed later in the thread with the Scion xB.
Action shot #1
Action shot #2 - FWIW, that's a box truck in front of me... to far ahead of me to be within the cutoff line.
Action shot #3 - With this one, note the distant road signs illuminated nicely.
Nice job! Looks like you mounted the ballasts in the same place I did (yours is a tad more forward on the drivers side) but looks good!
thanks guys... just glad they're in. it should've just been like a 2 hour ordeal, but those H7 holders truly are such a convoluted PITA!
Cool. Well done. How much you charge per hour? Any discounts for 2? ;)
lol, might actually be a good idea to practice reinstalling your OEM halogen H7 once before flirting around with the HID bulb.
Hot damn! they look bollocks!
I can't wait till I get back from FLA and get mine installed!
jandree22 it looks awesome!! Big difference from your stock halogens.
I installed 6000K on mine, and I will never go back to halogens in my future cars.
Now you need to go for a ride on a rainy night in someone elses car, like say a stock Ford Focus so you can appreciate just how terrifying halogen bulbs really are. I thought my wifes Subaru had decent headlights before I got my HID and I won't drive hers at night any more, nothing but yellowness and blotches of darkness BLEEEGGGCCCHHH! Glad you have "seen the light" LOL
glare issue with HID?
sorry to kinda thread jacking here.. ^^
since i install HID on my 5, i noticed some glare right above cut off line (kinda look like butterfly shape). which i assume need to be there to lighten up road signs.. however, since HID produce 2-3 time more amount of light, this glare should be greater for other drivers..
i know glare is not *blinding* other drivers but seems to *bother* other drivers.
i am copying some pics from scion Xb forums.. (my 5 has very similar glare)
This guy also tried to reduce glare by applying black eletrical tape on headlight.
Glare above cut off..
Eletrical tape mod ^^
Glare reduced.
i've been asking GT owners to post their cut off line to see the amount of glare factory HID has but *no one is willing to do that for me*(hand)
well. what do you guys think??
s
total ghetto mod on the xb, for sure. i'll be able to post pics of the factory hid output in a couple of weeks. just gotta wait for the trip from japan.
[U[/U]Duck Tape!!! LMAO Why in the hell would you stick tape on your headlights to fix an aiming problem? Besides whenever someone high beams me I just return the favor. You thought those were the high beams? Here you go ass-wipe! I actually had someone turn their headlights OFF after I did that to them.
hey slvrsleeper... since you have 55W HID kit.. don't you have *more* glare above cut off line???
just curious..
ps.. i am *seriouly* thinking to put some tape on my headlight..(boom05)
