Android Auto Newbie Questions
Hi,
I have a 2018 (KF) CX-5 that I'd like to get working with Android Auto but never used it before in any car and was hoping to ask some newbie questions:-
1. I understand I have to purchase an updated USB hub with the phone symbol on it use AA. I have the firmware on the latest 74.00.324 (thanks Candurin) but I can't see any menu option for Android Auto - not even greyed out - simply not there. Is that normal until I upgrade the USB hub? (Just wanted to check before buying the hub.)
2. My main reason for wanting AA is to use Google maps (my Mazda Nav is way out of date) but I listen to music mainly off a USB stick or car DAB radio. Will this work, music off the USB stick or DAB with the nav on Google Maps via AA?
3. Does the Google maps guidance still interrupt USB music to give directions?
4. Is it easy to flip between music and AA maps? Currently you just need to press the music or Nav buttons in the centre console.
Many thanks in advance, I have tried searching for answers didn't seem to find them!
We have a 2019 that includes AA/CP standard, so I can only answer from that perspective. I assume it works the same way with the hub:
1. I doubt you will see anything about AA/CP until the updated hub is installed.
2. Yes. There are two USB ports, only one can be used for AA/CP, but music will play through a thumbdrive from the other.
3. Yes.
4. Kinda. You actually flip between AA and native Mazda functions, by pressing and holding the Home button. If you're playing music from a thumb drive (Mazda native), it will continue to play when you switch to AA/maps.
4. I would add that, with apple carplay at least ( assuming AA works the same) . The shortcut buttons (nav,music) returns to the last active system(mazda or AA). So if i am using google maps and listening to radio, the nav buttons goes back to google maps in Carplay, the music button goes back to the radio in the mazda system. If i start using iTunes, the music buttons goes to iTunes instead.
I can confirm that this is the behavior with AA as well.
BTW, the touch screen is disabled for the AA menu (at least with the add-on/replace AA/CP USB module).
Touch screen with apple carplay for my 2018 CX-9 is only disabled when driving. At low speed or when stopped it works.
Perhaps, but this is a CX-5 forum/thread.
2017 CX-5 no touch for AA. It may be the same with 2018 CX-5.
CX-9, different story.
I've had a module fitted for a few weeks now and have recently completed a 3000 mile road trip using Google maps nearly everyday. Here's a few thoughts:-
1. The module I bought was not OEM but a "HMYC" branded one from Amazon. Seems good quality and fitting was quite easy following guides on here and YT.
2. Before fitting the module I upgraded to 74.00.324 firmware and the Applications menu did not show CP or AA options.
3. After fitting the module (without phone connected) CP and AA show up greyed out in Applications.
4. Connecting the phone (Samsung A55) doesn't always work and can sometimes (maybe 1 in 5) take 2 or 3 goes of unplugging to get it to connect. Tried several methods... "connect phone - start car", "start car - connect phone", "start car - wait - connect phone" but nothing seemed to reliably connect. Not sure if this a phone, hub or car issue.
5. Occasional lock ups - happened maybe 1 or 2 times per day when using Google maps. Complete lockup of AA. Unplugging phone and reconnecting got it going again. Again, not sure if this a phone, hub or car issue.
