mark@kartboy said:21.5mm is about 35% stiffer than 20mm. (21.5^4/20^4)-1*100%
Mark
mark@kartboy said:Thanks for all the info. Certainly $200 is way too high just for bushings. If we could make inserts only, I would guess somewhere around $30-40 at most for a pair. I leave open the possiblily that a new high performance bracket may be necessary. Also, we will look into some replacement endlinks. Our Subaru models are very popular, however the stock subaru links are C-shaped plastic, and flex quite a bit. The straight links on the Mazda can be improved somewhat, but not as dramatically as on the Subaru.
Thanks
Mark
StuttersC said:I didn't think that going from the stock 20mm to a 21.5mm would be to much a huge difference. But enough to be noticeable. I can already sort of get a little off throttle oversteer. Not really, the back end stands up and moves out from the turn.
Cool deal all around though. Thanks for tech info.
Mark
Kooldino said:
Just curious, why are those numbers raised to the 4th?
Kooldino said:
Wait...are you implying that you did the swap already?
saided18 said:whats gonna happen sunday?
Kooldino said:$200? Are you guys NUTS? They're little peices of poly/rubber???!!!
Kartboy: Assuming that they would be in the same cost range for you to make as the shifter bushings, then $25 for the rear set should work, if it's just two little bushings. Maybe a little more $ for the fronts if they're harder to do. I don't understand where they're coming up with this $200 number from...
The main thing we want is something that won't make any noise. Ever. If urethane has potential to make noise, don't bother with it. What materials do you have to work with? What are the ups/downs?
