i think the toe changed slightly as well. chojin posted these a long time ago:
Hey Everyone,
Here is the Exact TSB:
02-002/02 MAZDASPEED PROTEGE - TOE-IN SPECIFICATION ADJUSTMENT DURING PDI
APPLICABLE MODEL(S)/VINS
All 2003 and 2003.5 MAZDASPEED Protege models
DESCRIPTION
The MAZDASPEED versions of the Protege models requires less toe-in than the settings provided at the factory for both front and rear. At the time of pre-delivery inspection, the total toe-in setting must be reduced to the setting outlined in this bulletin.
NOTE: The purpose of the toe settings below is to provide a slight " total toe-out " condition.
TOE-IN ADJUSTMENT INFORMATION
Adjust tire inflation pressures to 32 PSI cold for both front and rear tires.
On the alignment rack, reduce total toe-in to the following specification.
Front total toe-in (-1.0 1.0 mm, -0.04 0.04 in, -06' 6')
Rear total toe-in (-1.0 1.0 mm, -0.04 0.04 in, -06' 6')
Inspect that the following settings are still within specification.
Caster angle (Front: 201' 1)
Kingpin angle (Front: 1259')
Camber angle (Front: -058' 1)
Camber angle (Rear: -048' 1)
Verify adjustment.
PDI CLAIM INFORMATION
The PDI time has been increased for the MAZDASPEED Protege model to include the toe adjust alignment procedure. Do not enter claim for the alignment procedure when performing PDI for this vehicle.
Regards.
-Shawn
