Aggressive fitment anyone?!
yea I agree on the camber not looking like -7 degrees. He has a custom rear pull, and if you would have asked, anybody could have told you a +15 on a 9 would poke like hell
btw, any pics of your setup reflex?
im not done yet. i have a 17x9 +30 ..i would throw out a custom panel all around cause im a body guy, but car isnt mine..its my girl car, n she have to switch between wheel for winter, n car has to be drivable all year round.. those wheel i post up befor r the wheel thats going on it. i tested, n its hella pokin lol.. so we'll lowerin it wit a little camber
damn! 10's? wow!
so chris, imma try this saturday. :)
I can only get about -2* in the rear right now. So this should help.
wish me luck!
You can do it your self in under 20 min. Heres what i did:
1. On the strut/hub, Take off the top bolt. Loosen the bottom one
2. Insert the bit in the top hole, then attach it to the drill.
3. Put one lug nut on and slide a pipe onto the lug nut.
4. Start the drill and pull up on the pipe. Be sure to put some PB or some cutting lube on the bit
thanks ak!
Good luck Pat! With my new 205/40's, I have a ton of clearance now. Even thinking about bigger spacer in the front (15mm maybe to get to 17x8 +20) ...
oh i see, i have a set of Drag Dr-44 17x7.5 +45 and its just not even with the fenders im on stock suspension too. what offset in 17x7.5 would give me a flush look? i was thinking 17x7.5 +35 or is that too much?
That is not too much. I am at 17x8 +35 with about -1.9 degrees of camber in the front, and I could probably stand to get a 10-15mm spacer before the lip lines up perfectly with the fender.
im thinking about getting some rota d2 17x7.5 but im debating on the offset since +35 still leaves a gap do you think +30 or +25 will do the job?
hands down most aggressive fitment on the forum:
no, those arent even his track wheels lol post a pic with his 285's on rpf1's, then I may agree with you.
And you ment to put, most functional, aggressive fitment
I'd say he's pushing the envelope further than anyone else has on a mazda... so, functional or not, its more aggressive than anything else posted.
