Hey guys, figured I'd clear up some confusion about my car (the silver MSP w/ black Enkeis).
-17x8 +45 offset with 235/40/17 tires for the track
- -1* rear camber
- 215/45/17s fit fine on the street
-Springs are standard rate Eibachs from Ground Control. F:350# R:250#
-Fenders have not been pulled or rolled. I simply trimmed off the lip with a cutoff wheel.
-You can run a 17x8 +48 wheel with a 215 and probably a 225. Once you get larger than 225, the tire may hit the rear strut. Front clearance should be fine.
-A 235/45/17 is too tall of a tire. If you want to get the car low and on 235/40s on the street, you'll need 350# or stiffer rear springs and adjustable lower control arms to dial in negative camber.
