Aggressive fitment anyone?!
this car belongs to one of my clients
I like how it's flush...if not poking a tad. Also, I like slightly beefier tires. Never been a fan of little sidewalls (hence the reason I'm going with bigger tires for my 18's)
what size tires are you going with?
I'm running a 215/35/18 tire on 18x7.5 wheels right now (+42 offset). I'm gonna go with a 225/40/18....massage the fenders....do a little negative camber in the back...possibly run spacers, too. (naughty)(naughty)
Yeah I definitely like the meaty tire look but I do it more for the grip then the looks...lol.
next time I pick up performance tires I'm probably gonna go with 245/45/16.
will look great on 225/40s bro, i want to see this setup :)!!
Oh....you will. Come spring, however (2thumbs)
I'm really liking the idea of extended ARP studs as well. But if I do that, I'm not sure what I'm going to do about the one lugnut per wheel I have that is a lock (not open ended....thanks 5Zigen)
i have 225/40/18 on my Works.. i will take better pics of those if you want, since im pretty sure you have the same wheel specs as me.
they are also the Falken 615s and measure closer to a 235 in width...
Awesome! If you could get some better pics of those and post them so I could get a better idea of it....I would HIGHLY appreciate it. (And I think you're right about the specs...I'm running 18x7.5 +42)
Def. not going to run 615's because I know they tend to run wider. It would look sick, though. ;)
ok Soze, im uploading a bunch of pics now so stay tuned.
btw i found a much better video for state of the union, but its bad quality,. ill post that too
ok so i switched to photobucket...
here ya go.
rears with -2˚ camber
fronts with -1˚ (and no engine weight)
width from behind
My HOOSIERs on the other side. 245/40/18 no 17x8 +45 (i think)
all meat sitting on the ground :)
comparing both from behind
