Aftermarket Fog lights
l337person
Mazda 3I
So my question is how many wires come of the connector for the foglight connector. Because i want to cut the wire comming of the connector. And take a wire to ground and take a positive wire to the parking lights right above it. And tap the wire comming right out of the fog light housing. Is that possible. Instead of going through the trouble of adding a switch inside of the cab and wiring it all up.
should be a 9006 bulb, so two wires, i believe one is orange and one black or blue. oj is power. aside from that it should be pretty easy to do. you just dont want your fogs turning off when u hit your highs i assume? the ideas pretty good. i'd go for it.
