EDIT:^^^ no other way around, colder it is, the richer it is, I believe since the ssafc doesn't adjust to temp. just the stock ecu, or something like that, but the more air comes in, maybe the MAF over compensates I guess and throws crap loads of fuel in there.. could just be bad stock tune/map from mazda to begin with at colder temps I think..
first off.. thanks wagon, I wasn't too sure if there was another one also
and also the theEZV after tuning a little bit today (couldn't too too much, I had just gotten a much better setting for 10psi on the Greedy ebc than I had before, I think I might need to tweak my 8psi at some point too.. and the fact that at first for a while there was a cop posted at the end of the straight away where I like to do my tuning runs lol)
but after doing a few runs, I realized that I forgot to add the coefficients into the datalogging for the wideband as well.. but I got 3 runs, the first 2 just to see what is was like on stock supermap, and the last one after I changed a small value up top.. but my point is that I was really confused because every single other time I have tuned and the last couple weeks at least  at 8psi, I was running crazy crazy rich even when it was warmer that it is now. and I get the setting for 10psi finally and it's almost too lean in some areas. I'm going to have to add fuel to the supermap which I've never had to do what-so-ever, so I was a little confused, so as of now, I am going over the data logging and making some notes and changing a few areas that need to come down closer to 11.5 instead of 11.8 or so in the high rpms (I stop at redline/ 6.5k rpm)
which brings me to the conclusion that since my 10psi settings for the Greedy were so bad and lagging and now I notice a much better response and I think I can improve it more at some time, is that just the settings difference and how it controls the turbo and wga plays a huge role in the maps.. when I get more time soon I will try to do some logging at 8psi and see what is going on, and screw around with the Greedy ebc settings at 8psi and see if it changes it..
more related to your question is that I guess so.. I am going to have to see if it changes in the next couple days at 10psi if it stays warmer, and then check to see what happens at 8psi.. but it's 65 here also.. so also do you have an ebc. or have you set the boost to anything different?.. also if it really was around  85-90 it would be much lower afrs at WOT compared to now, I wouldn't expect to see 10.0 all the way through the power band but in a few large chunks, yes..
should be interesting if I figure out a way to set my ebc to make it have a much better response than before, and somehow have it improve the afrs to some degree.. I dono how but oh well.
oh and also I should mention that the other week when I was getting really rich readings at 8psi, my EGR valve was really dirty, I cleaned it really really well, so I think that is having a large effect on the afr.. .theEZV I would try cleaning your EGR really well and see if that improves your afrs I know it made my car sound and run sooo much smoother and really open up instead of it kinda stuttering/sluggish and really rich
..edit2: also after looking at the data log runs for about an hour, I find it strange that after the first 2 runs between cells 9.5-10.5psi (remember the ssafc switches to the next highest cell once it hits half way, so that at 4.6k rpm and 10psi or so, it  will be on cell 5k rpm 10.5psi, it took me quite a while to grasp that, and it still is confusing sometimes) but anyways, 9.5-10.5psi at around 3.5k-4 or 4.5k rpm it is really rich, like in the low 10s, but when I changed maybe a small setting on the ebc to lower the end boost to around 10 or lower, and changed the "over pressure" to -1, the last run I did, the afrs were around 11.5 or so around that whole area.. I don't get it, but I just need to do some more runs to check for patterns.. other than that I am just adding some fuel to the very beginning, where there is low rpm but high boost at the start, and than again at high rpm and high boost for safety.. hope it stays consistent on me for once.
